查看: 4113|回复: 1
HT32F50230 硬件I2C 问题
发表于 2023-7-1 18:23:59 | 显示全部楼层 |阅读模式
新手求助!!
为什么发送没输出,是哪里存在问题吗!!!
是按照例程弄得程序~
求大神纠正~
#define 7708_ADDR 0x42
#define REG_ADDR1 0x0A
#define I2C_PORT GPIO_PB
#define I2C_SCL  GPIO_PIN_7
#define I2C_SDA  GPIO_PIN_8
void IIC_Init(void)
        CKCU_PeripClockConfig_TypeDef CKCUClock = {{0}};
        CKCUClock.Bit.I2C0 = 1;
        CKCUClock.Bit.AFIO = 1;
        CKCUClock.Bit.PA    =1;
        CKCU_PeripClockConfig(CKCUClock, ENABLE);
        GPIO_OpenDrainConfig(HT_GPIOB, I2C_SCL, ENABLE);
        GPIO_OpenDrainConfig(HT_GPIOB, I2C_SDA, ENABLE);
        /* Configure GPIO to I2C mode for Master        */
        AFIO_GPxConfig(I2C_PORT, I2C_SCL, AFIO_FUN_I2C);
        AFIO_GPxConfig(I2C_PORT, I2C_SDA, AFIO_FUN_I2C);
        /* I2C Master configuration        */
    /* !!! NOTICE !!!
       Notice that the local variable (structure) did not have an initial value.
       Please confirm that there are no missing members in the parameter settings below in this function.
      I2C_InitTypeDef  I2C_InitStructure;
      I2C_DeInit(HT_I2C0);
      I2C_InitStructure.I2C_GeneralCall = I2C_GENERALCALL_ENABLE;
      I2C_InitStructure.I2C_AddressingMode = I2C_ADDRESSING_7BIT;
      I2C_InitStructure.I2C_Acknowledge = I2C_ACK_DISABLE;
      I2C_InitStructure.I2C_OwnAddress = 0x00;
      I2C_InitStructure.I2C_Speed = 1000000;
      I2C_InitStructure.I2C_SpeedOffset = 0;
      I2C_Init(HT_I2C0, &I2C_InitStructure);
        /* Enable I2C        */
        I2C_Cmd(HT_I2C0, ENABLE);
//发送器件地址
void I2C_Ackpolling(void)
        while(I2C_GetFlagStatus(HT_I2C0, I2C_FLAG_BUSBUSY));
        I2C_TargetAddressConfig(HT_I2C0, 7708_ADDR, I2C_MASTER_WRITE);
        while(!I2C_GetFlagStatus(HT_I2C0, I2C_FLAG_ADRS));
void I2C_Send(uint8_t reg_addr, uint8_t *data, uint8_t length)
        I2C_Ackpolling();
        while(!I2C_CheckStatus(HT_I2C0, I2C_MASTER_TX_EMPTY));
        I2C_SendData(HT_I2C0, reg_addr);
        while(0 != length)
                while(I2C_CheckStatus(HT_I2C0, I2C_MASTER_TX_EMPTY));
                I2C_SendData(HT_I2C0, *data);
                length--;
        I2C_GenerateSTOP(HT_I2C0);
uint8_t I2C_Recv(void)
        uint8_t data;
        I2C_TargetAddressConfig(HT_I2C0, 7708_ADDR, I2C_MASTER_READ);
        while(!I2C_CheckStatus(HT_I2C0, I2C_MASTER_RECEIVER_MODE));
        while (!I2C_CheckStatus(HT_I2C0, I2C_MASTER_TX_EMPTY));
        I2C_SendData(HT_I2C0, REG_ADDR1);
        I2C_AckCmd(HT_I2C0, ENABLE);
    while(!I2C_CheckStatus(HT_I2C0, I2C_MASTER_RX_NOT_EMPTY));
        data = I2C_ReceiveData(HT_I2C0);
        return data;
上一篇:HOLTEK推出HT32F49365高性能Arm Cortex M4 32-bit单片机
下一篇:有单片机教程吗?
发表于 2024-4-2 21:13:13 | 显示全部楼层
水一个帖,搜I2C来的,竟然没有一个人回复,合泰开发生态太不行了,办比赛卷大学生的钱。
GMT+8, 2026-11-13 14:10 , Processed in 0.115744 second(s), 29 queries .
